Em150-2 software
Davetat2
100 µW
Just hooked everything up motor runs smoothly but software on the display page dosent show voltage or any markers when switches are pressed but they work and it continuously shows it as an em100 when I connect and it’s only doing 35a max according to the bms but I’m not sure if this is because it has no load (chains not connected so just a few second run) I haven’t changed settings yet it’s 100a bus 120a sport as it came from Siaecosy i only have 3speed and park switch connected they are working fine if I press connect on display page sometimes voltage comes on but doesn’t change and no rpm etc
With no load , you need no real power.
Thought that was the case that part didn’t really bother me once I posted this it brought up similar posts and I’ve sorted it I just had to turn CAN off and it’s all fine
