Am axnious to get a replacement for my E+ bike. Not sure of these internal hub controllers or their programability (not that I am much of DIY). Would like to get any insights or thoughts.
http://www.ebay.com/itm/48-V-1000W-FELT-Electric-Bike-Bicycle-Powered-by-Golden-Motor-Authorized-Dealer-/251157101970?pt=LH_DefaultDomain_0&hash=item3a7a213d92
Custom Electric Bicycle Powered by The New and Improved Golden Motor Magic Pie Electric Brushless Hub Motor Kit. Inspected and tested in the United States prior to sale and shipment.
Purchase only from an Authorized Golden Motor Retailer / Distributor to avoid imitation and copies! Have the peace of mind of purchasing from a U.S. based retailer specializing in custom electric bicycles and bicycle conversions.
Who said you have to ever compromise on taste when going green? In partnership with MODE Bikes of Costa Mesa, the entire line of FELT cruisers can be converted to powerful electric bikes that you would be proud to throw your leg over! Ride low, cruise high, or seriously scare yourself with virtually an unlimited amount customizable options so you can have your e-bike, your way!
The complete kit features:
Stable Rear Wheel Drive for uncompromising smooth acceleration
48V 5Ah Lithium Ion Battery Pack
Plug and play controller and power cables
Cutting edge hub motor technology featuring an integrated smart controller in the motor to reduce bulk
Variable voltage technology allows the rider to use all batteries ranging from 24Volts, 36Volts, to 48 Volts (Allows you to upgrade only your battery and not your motor when you need more power!)
Cruise Control (Usage not recommended in high traffic areas)
Programmable via optional USB data cable (acceleration, braking, max amp, speed, reverse, PAS engagement point)
Sturmey Archer Front Hub Brakes
Electromagnetic Braking (adjustable with optional USB cable)
Vibration sensor alarm - Failsafe operation mode (to mitigate hall sensor failure, and throttle failure)
The bike shown is the Felt Bonneville customized with cafe racer handle bars, Thick Brick tires, and Sturmey Archer front hub brakes. Power is provided by a GM MP2 48V1000W BLDC motor with internal programmable smart controller. One of the accessory included is a USB cable that allows you to program the motor from any Microsoft based computer. You can adjust max voltage, amperage, electro magnetic regenerative braking, reverse, PAS, and acceleration. Because the controller is internal to the hub, there is no additional controller box outside the hub motor. The battery included is a 48V5Ah custom built Lithium Ion Ping Battery with a 2A LiFe specific smart charger and BMS. The battery is enclosed in a motorcycle grade leather tool bag mounted under the seat. Depending on terrain, the max speed should be between 25-29MPH with range extension of 8-10 miles beyond what you can pedal. The shipping is in a custom built crate via freight with curbside delivery.
Note: The final electric bike set up may not conform to local laws and ordinances for street legal operation. Please check your local vehicle code prior to operation.
Seller reserves the right to end all auctions early due to retail sales of these same items. FELT bikes subject to availability and color scheme of the current model year.
