Xenarius
10 µW
Hi All,
My name is Phil.
I'm building my first Electric Bicycle and was hoping to have some input from such intelligent people as i seem to notice lurking these forums.
The Aim.
Build my firs e bike. Why? for fun!
Knowledge.
Worked for 4 years as a motorcycle mechanic so i have a decent idea about building and maintaining electrical circuits and advanced mechanical skills.
Some welding experience but no access to a welder.
Almost no experience with bicycle building or maintenance.
Tools.
Access to a full motorcycle workshop of tools, in the process of ordering some bicycle specific tools.
Parts.
Ok, so before i found this lovely forum and even after finding it Iv'e had a little trouble finding the info i need as to which parts to order since i don't know the names of most of the parts or the suppliers which i should look up.
The following is a list of what i have purchased already and any input would be greatly appreciated.
The Frame:
I found this frame on eBay, looks decent, haven't seen any reviews but the same frame appears to be on a few builds i've seen floating around.
http://www.ebay.com/itm/262779833552?_trksid=p2057872.m2749.l2649&var=561761879474&ssPageName=STRK%3AMEBIDX%3AIT
The Motor:
Seeming to be the simplest build i thought a hub motor would best suit a first build and after reading some reviews i decided on the MXUS 3K Turbo.
https://www.aliexpress.com/item/MXUS-V3-3000W-brushless-no-gear-hub-motor-for-rear-electric-bike-electric-bicycle/32649215681.html?spm=2114.13010608.0.0.5z9rgB
Suspension:
Spent some time trilling eBay for parts that matched the fittings of this frame and came across these front and rear shocks. I considered an air shock for the rear but dont really have much knowledge about them.
http://www.ebay.com/itm/192095147442?_trksid=p2057872.m2749.l2649&var=491990608290&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/162045818512?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Chain drive:
Bought these chain and sprockets however not sure if they are all compatible but seemed to be as far as i can tell.
http://www.ebay.com/itm/361336689258?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/332131644534?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/122367260873?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
That's all i have at the moment and there were some questions i was hoping you guys could shed some light on for me.
Seat:
Suspension or non suspension seat post on a full suspension frame?
Would a small racing seat be better if i plan to pedal regularly?
Wheels:
I want to lace the MXUS into a moto rim but not sure which size would be best. I was thinking 1.6-1.85 wide and 17, 18 or 19 inch diameter but not sure which would be better.
Should i also lace the front wheel with a moto rim or would that be overkill? I am a heavy guy (115 kg)
Brakes:
I want to go with hydraulic disc brakes and have seen some sets labeled as "E-Brakes". Would they be more suitable or should i go for a higher spec disc brake and get cutout sensors for the levers?
Controller/battery/LCD display:
Any suggestions for my setup?
BMS:
When is this necessary? i don't know anything about these =/
I would appreciate any help either by way of reply or pointing me to a resource i don't mind doing some research but right now there's just so many different things I'm trying to learn.
My name is Phil.
The Aim.
Knowledge.
Tools.
Parts.
The Frame:
The Motor:
Suspension:
Chain drive:
Seat:
Wheels:
Brakes:
BMS:
