et aOk, have been lurking and reading for a while, time to post !
Ok, first the saga of how I ended up here
Few months ago a bought an Electric bike for my wife. The requirement was for a bike that would allow here to allow her to ride with me and my 12 year old daughter on our mountain bikes allong bike tracks and the odd dirt road. Here in Aus we have the 200 W limit thing so I ended up getting a ladies step through bike fitted with a rear wheel Bafang and 36 v Lithium-ion for Green E-wheels in Melbourne. Have to give them a plug as they have been very patient dealing with me and the ensuing problems. I am actually in Tasmanaia so evrything had to be freighted. Anyway, first few rides were fine. The motor allows my wife to wind the thing up to ~ 30 Kph which is about what me and my non motorised daughter can keep up with pedalling. Needless to say the problem has come about on the hills. After a ride involving a ~ 3 k climb the bike failed on a steep pinch of the hill. After a bit of pushing and cursing we got the bike home. I have a bit of an electronics background so I did a bit of a diagnosis and concluded it was the controller on the basis of the 5v feed to the throttle and the Pedal Assist hall sensor was only ~ 2.5 v. Anyway, after posting the controller back, getting a replacement and fitting it the voltages measured the same. After a little more checking I determined the power supply to the hall sensors in the motor had gone short circut (and were pulling the 5v rail down) .. DOH ! Anyway, after explaining myself E-wheels posted me down another motor (laced into rim with cluster and everything). At this point I had done a bit of research and had found out about the reliability problems with Hall sensors. I then ordered a sensorless controller from Brett White. Guess what - it hasn't turned up (after three months). Anyway, fitted the wheel and all was good till a few rides later when the motor failed again on a similar hill. The problem in our case seems to be a combination of the string used to hold the cabling and the heat shrink tube used over the leads of the hall sensors. Obviously a bit of heat and the string causes the leads to get forced tohether and short. After reading this forum I was expecting to see some problems with the gears but they looked fine. I attribute this to the fact that my wife only ever uses Pedal Assist mode so the bike is always moving before the motor kicks in.
Anyway, apologies for the essay (ah thats off my chest). Now I can replace the hall sensor without much drama but want to get a bike together that will be reliable. What I am thinking is one of the following:-
1 Replacing the Hub motor with a higher pwer one. Basically, we're not after more speed just more torque for the hills. Ideally something like the BMC 600 w Torque version would be the go. This would be very expensive to get to Aus I imagine.
2 The other option I have been thinking of is adding a front Bafang motor to the bike and additional controller. It would be controlled by the existing throttle and PAS. A switch would allow it to be switched on when required. It would just freewheel the rest of the time. The other thing to note is the Bafang motor we have is "black" motor which is normally a front wheel config anyway ? I figure I can get some spare gears, etc which would be compatible across both mtors.
The idea is this would give a bit more power/speed on the hills and horfully reduce the heat generated. The other thing I was thinking that the the low voltage cutoff would save the motors if they are too heavily loaded bearing in mind its a 36v 10ah unit.
So has anyone tried a dual Bafang setup ?
