adrian_sm said:
Sorry to hear about the failure. Was it just the ESC that blew. Wonder if the high kV contributed?
I love the simplisity of your cable actuation. Means you can easily disengage, as well as adjust the amount of engagement. I needed to play around with all sorts of geometry, springs, dead-stops and what not to get mine to work.
- Adrian
thanks. i actually like the idea of the automatic engagement of evtodd, kepler, your drive, and i know there are a few more out there that do that also. i opted to do the clutch-like setup because i knew i didnt have the tools or materials to make one that would automatically engage, or i wouldnt know where to start. i wanted to use the ideas of previously successful ideas and try to get it to work, because i know goped used a similar system on one of their scooters and it was in production for quite a while. :wink:
it was just the esc that blew up, because when i took it out that one day, and got snow on it, it started cogging real bad, so i brought it inside and i stared at it for a bit and it was just soaked. so i wiped it off and tried to power it up and thats when it gave me the magic smoke, and about a good hour of the lingering smell of burning electronics
so i learned(i should say re-learn for some of them...lol) a valuable lesson that day, 1) heat-shrink is on electronic things for a reason, 2) keep my electronics away from water, 3) learn how to use a blowdryer just in case something like this happens again. :lol:
thats the thing about the high-kv motor. im running a 5/8 inch roller to compensate for the high kv(670kv), and i know some of you guys are using the actual motor can, which is like 2 1/2 inches(the 63-series motors, ~200kv). im hoping using the small-sized roller compensates, sorta like gearing down so i can rev it out. i calculated that ill get around 17-20mph on it if my calculations are correct
deVries said:
def215 said:
the drive i have is sort of like a clutch-type setup, similar to a goped bigfoot model(where i got the idea from). its a lot like a manual clutch.
Looks to be an excellent idea. 8) When you get it working again, please post some video showing the cable engagement & roller going onto the tire. ES members would love to see this working up-close in detail & in action
:wink:
Thanks!
ill try to post video of it once its working again, which should be like 4 more weeks, since i ordered another esc, which is the same one i had on there, the mystery 80a pentium controller. im starting to think that i shouldnt run it on a fully charged 24v sla pack
in the mean time, the bmx works if i want to ride, but the weather is still crap
