flimflamphlegm
10 µW
- Joined
- Dec 31, 2015
- Messages
- 6
So far, my theoretical build is:
Carvon single hub motor/trucks/wheels
2x Turnigy 20c 5000mah 6s li-po (in parallel)
Wiiciever + nunchuck
Parallel Charging Board
http://www.hobbyking.com/hobbyking/store/__31314__Hobbyking_Parallel_charging_Board_for_6_packs_2_6S_HXT4mm_.html
IMAX Charger
http://www.hobbyking.com/hobbyking/store/__58285__IMAX_B6AC_V2_Professional_Balance_Charger_Discharger.html
Would these Bullet Plug Splitters be ok?
http://www.aliexpress.com/store/product/XT60-Female-Connector-to-4-3-5mm-Banana-Plug-Female-Parallel-Charger-Cable-Extension-12AWG-20CM/727847_32485868443.html
http://www.hobbyking.com/hobbyking/store/__17672__XT_60_to_HXT_4mm_Battery_Adapter_Lead_2pc_.html
http://www.hobbyking.com/hobbyking/store/__18604__HXT4mm_Battery_Harness_14AWG_for_2_Packs_in_Parallel.html
REALLY rough mspaint (i'll make a better one tomorrow): http://imgur.com/TUbig6M
Newer sketch:
http://imgur.com/Pipa78s
Is this ok?
I also have a couple of questions:
The FVT ESC has a built in power switch. Does this suffice as an on/off for the board or no?
Are the default FVT settings ok for the carvon? I read that the default settings were ok for the SK3, but i'm not sure about compatibility with the Carvon motor.
Is there a XT-60s on hobbyking? I can't seem to find an XT-60s, or does only the XT-90s exist?
What AWG wire should I get?
Also, does anyone know of any <$50 boards in a similar form factor to the Loaded Truncated Tesseract?
Thanks a lot!
IMAX Charger
Newer sketch:
Is this ok?
Thanks a lot!
