I've been trying to find the links and info to answer this right, but it's spread out through different PC's and the 60 page axial thread.
I think what you are referring to is coil pitch, span, pole pitch, span, and their related coil and pole arcs. There is a lot of YouTube videos on it once you use those words in the search. I haven't found the one in particular that I wanted, but here's a link to get close.
https://www.youtube.com/watch?v=pfj4w2Jz3xA
https://www.youtube.com/watch?v=5pnbFmdi4Mc
Also go to Goggle Images and use those words to find what your looking for, that's what I usually do first.
Page 36; https://endless-sphere.com/forums/viewtopic.php?f=30&t=97860&p=1526164&hilit=coil+pitch#p1526164
There are a lot of youtube India based lectures on motor design too,.. they tend to look at it from a mathematical and geometric point of view, which is understandable, but not my strongest suit. Beautiful if you can understand it though.
Anyway, motors use 180 electrical degrees in a circle, and everybody else uses 360 mechanical degrees, so right off the bat it gets confusing.
Going from memory, and still looking for the links,.. you draw the diameter of the stator. Then draw in the number of coils you are
using with sides touching, plus one extra. Then remove the extra one and adjust the rest evenly,.. this should get close to the spacing needed. The spacing is also connected to different orders of harmonics, like the 5th and 7th and so on, and I see talk of 150 degrees for most modern motors, but for us noobs,.. not really on the radar 'yet'.
To get the core size you will need to know and add the thickness of the coils sides or copper fill, the resulting center hole will be the core size. Core tooth overhang, shoe, or lip spacing between cores is usually around 3 - 4mm or enough to get the wire through to wind the coils.
Magnets are a little different and can touch, as in most hub motors, but usually are spaced 3-4mm too. It gets more complicated if your after the greatest efficiency, and the pole arc winds up being around 75 percent of a full pole arc, or touching magnets.
All in all, we just look at what most motors are doing and copy it, but it certainly helps to know what is really going on. Hope this helps.
Motor designing from scratch makes you go down these roads,.. study these things for a week or so and you should have a much better handle on it.
