If you plan to ride mountain trails, you need to build lighter. Under 80 pounds at the most, 70 much better. Don't use a motor that is too fast, for it will overheat very quickly climbing in a 26in wheel. 24in is the smallest wheel that will ride good in the mountains, that would make 25in OD with a fat DH tire. A 26in with a 2.8 tire makes 27 and rides real good, but will need a slower motor. A heavy rim and tire will eat a lot of your performance with inertia, and mountain trails require the best acceleration that you can achieve so I prefer the best DH rims and tires to any motorcycle wheel. Get better top speed with higher voltage, 24s Lipo will give speed to a slow motor and an 18 fet 4110 controller can be upgraded to 150A, that is enough to make a climbing beast.
A big motor with slower winding is best when the trails are bad or technical, but that means serious suspension mods to achieve proper rebound tuning. A light motor will be good at speeding the nice trails, but would need liquid cooling to climb slow technical trail. I use 2 bikes to ride the best of both slow and fast trail conditions: One with a big slow motor and the other with a lighter, faster motor.
