John-in-CR used a hubmotor as a non-hub and I want to do the same for a longtail cargobike (plenty of room in the frame for any chosen options). http://endless-sphere.com/forums/viewtopic.php?f=6&t=26932&start=15#p389622. 44V LiPo, Probably only 1,000W.
The smaller Crystalyte 406 hub motors don't seem to be available, so I plan to order a cell_man MAC geared hub, which is about the same size as the 406 ( http://www.emissions-free.com/catalog/i1.html ). I've been pondering ways to incorporate 3-speeds for the motor by using a Nexus Internally-Geared-Hub (IGH). I can key a freewheel to the MAC threads so it can be reversed if needed, or, I may attach a sprocket to the disc-brake flange on the left.
I plan to use it as a 2-speed in daily operation, with first gear reserved for especially steep hills. I will pedal some, but it will be more of a moped commuter. Any ideas or warnings welcome. I'd also appreciate parts links that could make any of these options more doable. I can make any custom sprocket mount adapters that will be needed.
A. Left-Side-Drive Using the IGH as a de-spoked transmission/jackshaft, possibly use a belt connecting the motor to the IGH (primary-drive). Nexus-3 is available in a trike hub, which already has a second sprocket attached to the shell (can be used as a sprocket, or, used as a mount for a belted pulley)
Pros: adding a 2:1 drive between the motor and IGH cuts the torque applied to the IGH in half, making the weaker Sturmey-Archer IGH a viable option. Complete separation of stock pedaling system. I think that with the IGH flipped over, the freewheel is turning in the correct direction while using its stock configuration. This means I may be able to easily connect the motor to the IGH body with a solid cog bolted to the Hubs disc-brake flange (whether I use a chain in the primary drive, or the cog is merely a mount for a belted pulley).
Cons:
B. Series-Drive (like the Hanebrink http://elescooterparts.com/J/6.jpg ).
Pros: I have a GGoodrum double-freewheel adapter, and this would be the easiest to put together. If motor is mounted on a rear suspension arm, no motor-chain tensioner is needed (pedal chain tensioner for chain-stretch less of a problem)
Cons: It may require throttle snubbing to prevent shock-loading the IGH teeth and breaking them.
C. Parallel-Drive (like GGoodrums bike http://endless-sphere.com/forums/viewtopic.php?f=28&t=12267 )
Pros:
Cons: May be too wide to fit on some frames drop-outs with double freewheel? Limits pedals to 3-speeds (not actually a problem for me). May require snubbing the throttle to prevent IGH tooth breakage.
Cons:
Pros:
