Got a response from gng. Wppwrently the 48-74v controller was. Intended for 60v batteries
Any one has a clue what is meant by " plug in the self learning wire"? Right now this wire is not used at all. ?
Thanks
Dear Pavel,
I see what happen. Just asked the controller factory and they have set the low voltage cut off to your controller and we would not have that in next batch.
The controller self detected the battery to be 60V, and thus set the low voltage cut off at 54.4V.
There is a way to solve this problem:
please find a 48V battery (or if you can discharge your current battery to be lower than 52V)
plug in the self learning wire again.
The motor will set the low voltage cut off base on 48V battery.
Unplug the self learning wire.
The controller will be able to use under 54.4V.
