So I hooked up a Golden Motor 1000W 48V this weekend to try it out. Under power it seemed to work OK. Then I pedaled a few revolutions. Then I stopped. The chain kept going, trying to drive the cranks. When I forced the cranks to stop, the chain spilled over the top of the rear cluster onto the derailer and everything jammed solid.
I tried it again on the bench. When the freewheel bearing lockring is torqued correctly, all is well. When I apply torque to the cluster, the freewheel tightens against its own bearings and locks up. At that point the cluster is locked to the wheel, and no freewheeling is possible.
Anyone else have this problem? Regular freewheel tools don't work (of course.) I can get the entire assembly off the wheel by taking the lockring off the cluster and taking the entire freewheel off, but then ball bearings spill everywhere and it doesn't fix anything anyway.
