MrDude_1
dnmun said:those 35V capacitors are on the 12V rail that is used to drive those relays. i think that three terminal device surface mount soldered to the surface on the right just below the B+ input is the 12V or maybe 24V regulator U6. Q9 and Q10 are the mosfets that drive the two relays and are controlled by U9. you can see the gate drive traces running from that 8 pin SOIC to the gate resistors and then to the gates of those mosfets.
i can see the programming leads to the controller too and those might allow you to reprogram the HVC.
I would hack the serial communication myself, if I had a programmer for it.. but the only way to use it is with the "goprammer" a hardware programmer that is extremely expensive, and impossible to find used.
If someone were to lend me one, I would spy on the communication and write a software equivalent.. (I am a software engineer/ systems analyst)
But without the Goprammer I cant do it. with one you can also adjust the ramp rate of acceleration and a few other cool tricks. manual for it is here: http://www.go-ped.be/Technical%20manuals/ESR%20MANUAL%202.pdf
it would also help me test that I get 100% throttle when I make my custom throttle...
When I get home tonight I plan to tear the sticker off that IC, and see if I can find any numbers on it.
btw, what makes you think its a 12v rail? the batteries are in series before being connected to the controller, so everything (other than the 5v logic) should be a 24v rail.... right?
