I think the RH212 would be great performer for a motor with a 27mm stator and 0.35mm laminations. When provided the same input, the performance is very similar to the 5T Leaf, so I use it with the Grin simulator, along with the Leaf, to guesstimate how the Leaf may handle heat on a climb (the Leaf isn't modeled for heat).
Adjusting the Kv of the Leaf to match the speed of the RH212 fast wind (with Statorade), the torque and power graphs are nearly identical.
Our ebike motor simulator allows you to easily simulate the different performance characteristics of different ebike setups - with a wide selection of hub motors modeled, and the ability to add custom batteries and controllers and set a wide variety of vehicle parameters you'll be able to see...
ebikes.ca
Unadjusted, the Leaf's speed, torque, and power extend further, but still still consistent with the RH212 within it's range, and close enough for my estimation purposes.
ebikes.ca
So, on a 10% grade, at full throttle, the RH212 melts down in under 7 minutes, but with a 30% wider stator, I'm guessing the Leaf can go 10 minutes.
ebikes.ca
Of course I never climb at full throttle, since I've determined that I can climb 10% indefinitely when riding at my 20mph sweet spot for climbing hills, and so can the RH212.
ebikes.ca
On a 20% climb, the estimate to actual are strikingly close when compared to my real world temp testing data.
With additional cooling, it seems like the RH212 would be great to hotrod.
