John in CR
100 TW
With a temporary reprieve from rainy season I've been riding instead of building, but it's time to put this Nexus3 to the test. In order to still use bike chain I'm going with larger sprockets. I'm going first with the big hub motor that has pushed me past 60mph in a 20" wheel, but using it outside the wheel. My interest isn't speed, but hill climbing without strain, so I have a 36t sprocket to attach to the cover of the hub motor, and a 44t sprocket already welded to the 18t sprocket that comes with the Nexus geared hub, and the Nexus hub mounted in a 20" wheel.
As quiet as possible with chain that's turning in the 600-900rpm range is what I'm after. Something I've seen on very large chainrings is filed off every other tooth or 2 out of 3 teeth. I'm thinking of doing the same while I still have these sprockets off the bike.
How far should I go? On the front sprocket, should I grind off every other tooth or 2 out of 3, making it an 18t or 12t sprocket of large diameter. What about that rear, go make it a 22t sprocket, or grind off 3 out of 4 and make it 11t?
OR considering that it is quite likely to go unchanged unless the gearing is way off, just leave the sprockets with all teeth intact?
John
John
