Makeitfarster
- Joined
- Apr 2, 2020
- Messages
- 81
I tried to message you but its disabled.
Sent from my SM-G975F using Tapatalk
[emoji1787][emoji1787][emoji1787]Ianhill said:I disabled it after hastle from crazy horses with flat earth views, I'm not far from Brecon, bwlch mountain.
Lol we do lick a window or 2 down here plenty of stars to admire PMSL.
Makeitfarster said:Also I want to stop using my makita batteries for my scooter so I need some advice on what to do from you guys. I'd like a 72v 20-40ah.
I wouldnt know where to start. Build from scratch, lipo packs strung together?
And advice would be appreciated...
And I thought the e scooter was born in the 70s.Ianhill said:Fairplay to the modern gal proberly like a fwd razor e300 but over 100 years ago crazy
What was the original scooter stuff running at? That's what the parts on it were intended to be used at...so if you need them to do signficantly more than that, it's probably a good idea to replace them.Makeitfarster said:Now I see it in black and white I reckon its just a cheap crappy fuse holder, its the one that came with the scooter.
That looks like the heat is at the connections between fuse and wire, based on where the swelling / melting is. I would change that out to a bolt-on fuse that bolts directly between your battery terminal and your controller battery wire using ring terminals. They won't take up any more space, and you don't have to worry about good connections if you are properly tightening the bolts and using the right washers and such. You just have to ensure it's all electrically insulated so it can't touch anything (heatshrink, etc around the terminals/bolts, or use an enclosing fuse block, etc)
What is the current limit of the controller? What is the max current the battery ever has to output to the system? What is the wire gauge between the controller and battery? Those are some of the important things that determine the size of fuse you need to use, because it has to be big enough to not blow in any normal usage, but "instantly" blow in the event of a failure that would cause a wiring or battery / etc fire. Generally, you might be able to size the fuse for an amp rating of twice the max the controller should ever draw, and as long as your wires and other parts can handle that for a minute till the fuse blows, it'll work. It'll blow faster the more current thats' flowing, so a direct short (like wiring short) could blow it immediately but a long uphill won't.Can you reccomend something for me?
Im running 48v 1800w
I couldn't find any info on "Battersby" that has anything to do with ebike/scooter stuff, so you're going to have to provide links to the stuff for me to get info that will help you.Got a 52v 2000w 25ah Battersby on way.
