TheThirdWheel
1 W
- Joined
- Jan 31, 2014
- Messages
- 55
Hello all,
I recently put together a 24S2P (72V, 20Ah) LiFePo4 pack made up of 10Ah Headway cells for an e-bike project. It is connected to a BMS that has performed flawlessly in the past.
After the pack (about 50% charged) was installed into the bike, the bike worked great. Then I charged it, and that's when the problem began.
The controller switched on and the Cycle Analyst switched on very briefly but then switched off again. I plugged in the charger and flicked on the power. The charger said the pack was charged, so I switched everything on again and this time the CA stayed on, however I suffered major voltage sag (as low as 60V) when applying the throttle on the UNLOADED wheel.
Knowing the problem was most likely a BMS issue, I accessed the pack and started testing the voltages at the balance leads. 2 banks of cells were low. One was ~2.5V, the other was 0.3V. Every other bank read a healthy ~3.65V. There was also a clear liquid around the low voltage cells, which smells a bit like exploded capacitor...Upon removing the 2 cell banks (2 banks of 2 parallel cells each), I separated them into the 4 separate cells and began testing voltages. Both the cells that were in the 0.3V bank read under 1V each. I also noticed under close observation that the silver cap/seal under the main positive terminal of one of them had lifted. It looks like the cell had blown, died, and taken down it's parallel counterpart with it.
Upon testing the other bank, one cell was fine, while the other was at 2.5V, however under the miniscule load of the multimeter, I could see the voltage plummeting down until it settled at 0.8 volts!
I tried charging the low 1 volt cells but my charger doesn't even recognize a connection (insufficient initial voltage). When I charged the 2.5V cells the charger immediately said the cell was charged, but once again I monitored it's voltage sagging right down under the load of just the multimeter. I assume it's dead since it can charge/discharge in less than a second.
I thought these Headway cells were pretty durable and quality, but for one to just blow its top on a 2C discharge makes me feel ripped off.
I know that a bad cell will drag down any other cell in parallel with it and the BMS can do nothing about it, but why did the next cell in SERIES also die?
My BMS is wired correctly, if it wasn't the e-bike wouldn't work.
Has anyone else had LiFePo4 cells just up and die (my Headways have less than 20 cycles on them and haven't been abused).
What could be the cause of this problem?
Thanks everyone.
Thanks everyone.
