Not sure I understand the question. Do you mean if the CA can accept DC, or if the samsung/apple converter can accept DC?
And if the latter, you could just hook it up to your battery (no need to hook it up to a CA, unless you're measuring the converter's power usage).
As far as using various converters, well, you can use many devices that are labelled for 100VAC-240VAC on DC even at much lower voltages, though some of them will need higher start voltages than they'll run at once started. Even many CFLs will run on your ebike pack (I used to use them for headlight and tailight).
Some stuff doesn't work, but you can find lots of them to try at Goodwill and the like, for next to nothing, or on Freecycle for nothing. Maybe even at yard sales, etc.
If you look around the forum there are a lot of threads and posts about this, with various suggestions on how to mount, connect, modify, etc., if you need to.
As far as specific chargers go, I have had the least luck with Apple branded chargers and power supplies, but I haven't got anythign recent to try out.
I have had at least one 12V + 5V output unit work off a 58V-charged pack; it was off an external harddisk of some type AFAIK. Don't remember the brand.
