New to e.bikes, bought this Izip Ezgo some time ago. Trying to get it going!
Came without batteries or box so I am using 2X 12v car batteries in series to test it mounted on rear carrier.
First test on road no action at all.
Now in shed with back wheel raised.
The only way I can get any action is as follows.
1.Open up throttle twistgrip , then
2.Connect battery. ie. touch pos. supply lead to battery plus.
Sometimes the wheel turns , other times there is a whirring from the motor but wheel doesn,t turn. sometimes nothing ,but turning the wheel backwards a bit and reconnecting power , and it may run.
Once running, turning the pedals slowly and wheel speed increases as I understand it should?
I can't start the motor by pedalling the machine with the battery connected whatever I do with the throttle.
Don't know how old it is but controller (Ananda) is dated 2006.
No obvious damage anywhere. Some of the colour coding in the 'electrics box ' seems a bit off but can't
find an exact wiring diagram.
Any help, comments, ideas gratefully accepted. Thanks!
