First of all I would like to say hello and big thanks for being such a great community. I have been reading this forum for a few weeks and I have finally decided to write my first post.
I don't want to reinvent the wheel so I've decided to ask for your opinion on preferred motors and batteries. There's quite a big choice of components so it's really difficult to make a decision.
MY GOALS:
1. Full suspension bike
2. No pedals
3. Top speed around 40-50kph (30mph)
4. Range minimum 30km while off-roading and having fun and 60kmh commuting on flat ground. The more the better.
5. I need torque and acceleration more than top speed.
6. Free wheel. I don't think I will benefit much from regen.
MY POSSIBILITIES:
1. Can weld aluminum
2. Know a lot about suspension and bicycles
3. Can solder stuff
4. Can work with fiberglass (like for a battery shroud or container)
I am in the process of completing the bicycle parts and the electric stuff will come next. The bike is a Giant Warp with Marzocchi Bomber fork, hydraulic disc brakes. As in the photo below.
MY MAIN QUESTIONS:
1. Which motor should I choose? Depending on the motor itself I can connect it directly to the sprocket by the rear wheel (a big sprocket like in motocross bikes). I can buy a motor with an integrated reduction. I can also use the bottom bracket to install a secondary reduction. With no pedals and cranks I can weld the footpegs slightly above the bottom bracket. So the engine cantransfer power to its own primary reduction which is attached to the BB, and on the other side of the BB is the output which then connects to the chain going to the back wheel.
2. Should I use Headway LiFePO4 batteries? Each one of them has 10Ah/3.2V. My initial plan is to use around 18 batteries for 57V and 10Ah. Is that enough? Or maybe there are other battery options which give me more flexibility and lower weight? I have no experience so I can't really tell whether I need more voltage or more ampere-hours in my case.
I also have a plan to use two sprockets side by side, like in a typical bike cassette. They will have a large difference in teeth count. By using a spring-loaded chain tensioner, I can either have more torque and low speed (30pmh) and by popping the chain by hand onto the other sprocket, I could increase speed and range and decrease torque (which is not necessary for longer commuting on tarmac).
I would be grateful for any help
Below is the photo of my bike. The blue circles are the batteries and the red rectangle is roughly the space I have for the engine and reductions (15x25cm). I can double the battery count by placing them on the sides of the frame if need be. But will it be too much weight.
MY GOALS:
2. No pedals
MY POSSIBILITIES:
3. Can solder stuff
MY MAIN QUESTIONS:
