JoltJockey
Hi there!
I'm planning on building an experimental e-Dirt Bike . I'm mainly trying to figure out how I will transfer power to the 27/½" rear wheel of a Mountainbike.
POWERPLANT:
is going to be: (2x Flipsky 7070 110KV 4200W - motors powered by a 16S 7P battery pack (24,5Ah | ~64V | ~175A max. Cont.) through a Flipsky-75300 200A dual FSESC.
FIRST IDEA:
was a "mounting-platform" for motors and gearing on rear-rack. -> GT2 15mm pulleys, belts and idlers (1:3 into 1:2 - reduction) transferred to a driveshaft with a 6-speed bicycle cassette 14-26T going to a dedicated single 60T sprocket (~80 km/h speed at max rpm = goal) mounted in place of the rear disc or on the right side next to a narrow 3-Speed Cassette connected to the Crankset for peddaling with a seperate chain.
Some rough calculations on the forces the chain might survive: E-Bike Chain -> rated for 600W assistance and maybe 400W of pedalling for combined 1000W -> i could see the chain running at this torque and with an RPM "only" twice as fast as a human would achieve 2000W total. Still not enough.. let alone shifting the cassette into low-gear.
2nd IDEA:
was to ditch the cassette and instead have one ~24T sprocket at the end of each motors belt & pulley - reduction + two chains going to 60T sprockets on each side of the hub thinking two good chains might be able to survive like 400 miles of riding.
But from what I gathered this chain system would be too fragile still.
QUESTION:
Now I'm researching Moped, Dirtbike, Trial and similiar compact sprocket and chain solutions that were designed for the range of torque and power I'd like this project to put on the road. A single speed solution + ideally a way of decoupling from the peddaling action.
I'm thankful for any suggestions on solutions and maybe your own experiments and knowledge from similiar projects!
Ride safe!
POWERPLANT:
FIRST IDEA:
2nd IDEA:
QUESTION:
Ride safe!
