Hi guys.
I've been reading and reading and getting a lot of information, but I might have to ask a question myself. Hope someone can help.
I have a Felt cruiser, single speed with coaster brake with 3" tires. I love the bike and the ride and style but it's a little heavy with a single speed to ride to work so maybe time for a motor. The coaster brake is pretty poor so I'm reluctant to use a front hub motor and rely solely on the rear brake, so my plan is to install a rear motor and then switch out my front hub with a sturmey archer drum brake (very good reviews apparently and I dont have disc tabs on my forks). The drum brake will be a very simple switch out with a rebuilt front wheel and be more economical than going to disc brakes because of the need for new forks, new hub, disc calipers etc.
My question though is I have 3" wide tires on the rear, to deal with this my coaster brake hub uses an offset rear sprocket to clear the tire. The center line of the sprocket sits 10mm inside my right hand side rear drop out (space between drop outs is the typical 135mm). I'm nervous that if I get a single speed free wheel rear motor that the chain may not line up and hence rub on my tire.
Can anyone with either crystalyte (40X), bafang or other rear hub motors give me a measurement of where their free wheel cog sits in distance from the inside of their drop out? I'm wondering if maybe I just get a 3 or 5 speed freewheel (no changing gears) and just use whichever cog lines up with the front sprocket and give me tire clearance as well but it's a bit of a mystery bag on exactly which gear I will end up with. I don't really want the gearing to be too tall.
At the moment I'll be getting a rear wheel built with whichever motor i decide on, not sure at this stage whether to go for a clyte or geared bafang or another option (aren't too many in rear??). I'm in SoCal and only need to ride 5 miles to work, very flat riding really with a few low grade hills (really quite low or short). The bafang appeals on price and I know I will have the torque to haul my heavy cruiser and me up the inclines but maybe the clyte is a better choice? Only really want a speed of 20-25mph (30 would be nice for bursts with good brakes but I'd settle for slower).
Would the bafang and infenion controller be a good choice and the I just volt it to my desired speed. It seems a nice option because I can add disc down the track and the price is nice given I have the cost of building the wheel anyway (I'd prefer wide rims).
