What is safer ? 1200whrs in 16 lipo pouch cells or 1200whrs in 110 cells of 18650.
I started thinking about the odds, almost 6.8 times the amount of cells and interconnects, then I thought about a thermal run away in a hot glue pack of 18650s. Are we all pushing our luck with hot glue packs ?
I have had both a HK lipo and a hot glue 18650 pack drop cells and go red hot. Both packs didn't catch fire or explode. On both occasions I only noticed by touching the packs while handling them at the end of a ride.
I know 18650 are inherently safer by design, but the cells we buy are not the protected type right ? They do have venting though ?
Lipo pouch cells are really only less safe by the fact they don't have a protective shell, same chem inside right.
I whitnessed a blower battery at work catch on fire and explode into flames when it got wet, it was just as fierce as the fire I saw from one of my lipo packs I punctured with a Stanley knife.
Either way both types get real angry when pissed off.
I'm actually now starting to think lower cell count and less interconnects could be safer if the pouch cells are protected physically.
Most new laptops etc don't run 18650 any more, they run pouch cells as they are thinner. So all they do is protect the cells from puncture and a few other electric smarts. So you have big business using pouch lipo, not lifepo4 either they are lipo.
I'm almost thinking some heat and fireproof layers between big 20ah pouch cells may be the go. Then each cells also protected from puncture.
