MattyCiii
Hello all you V4 drive users, I have two questions:
1) How do you "test" for proper belt tension? Like, is there an optimum amount of deflection when you press down on the belt?
2) What's a good way to set the tension? I mean, with the DaVinci drive there's a screw one can use to just dial in tension then sock-down the mount bolts to lock it in. Is there an easy way to get the V4 tense, until one can tighten down its bolts?
