ebike4healthandfitness said:
For any given kinetic energy heavy and slow will have less energy lost to aerodynamic drag compared to light and fast given both have the same coefficient of drag and frontal area.
Actually, both aero drag and kinetic energy go up with square of speed.
A 100 kg vehicle travelling at 10kmh will have roughly 300 joules of energy, at 30kmh - 3000, at 50kmh - 10000!
Now, 10000 joules is 2.8wh, and there is no way you can recover more than a small part of it (most will be lost to aerodynamic resistance), and you'll spend more (if you lay on the 'gas' - *significantly* more) than 2.8wh acceleration to that speed.
When it comes to hills however, things are different.
Let's assume you want to maximise your average speed while minimising battery draw while going in hilly terrain.
This means you'll be going up hills at your preffered average speed AND going down them at same speed, so aero losses remain the same.
Assuming a decent efficient system (80%), for each 1000 meters climbed for a 100kg system weight, you'll be using 340wh to 'just climb' and recover 217wh while descending, so you spend only 122wh overall.
Given efficient and powerful enough motors, that is pretty much like more than halving your weight when it comes to hills and energy expenditure.
Now assume better aero, 170kg of weight, 4000-5000 meter ascended per trip and you'll see why I'm so keen on regen
Btw, I have 2.3kwh lifepo battery that cost me about 250$, it can give out and absorb enough power to meet my needs - no fancy new tech needed. It does weight more than a typical bicycle though...
