Well most fires are related to poor charging practices, but poor cells can catch fire still. I have not read a single case here where a battery burnt up for no reason though. Nor one burning up that was charged as an ev should be. All the fires are related to charging with non ev (generally rc) kit, or in rare cases physical damage. So using the forum as a guide, you are safe unless you use the wrong kit.
Your phone, my phone, your neighbours phone, they all have a lipo battery. Most laptops too. But last year 150 odd laptops did light up on planes. Iphones lit up. Things do burn up, It is simply an odds game. I come back to the reports here though. Nearly all fires are from poor charging practices. You must use a bms and ev charger for reasonable odds. You live in a block, and if you burn it down through negligence I can see a whole world of pain ahead for you. You must do it properly. Then all you risk is that rare chance you actually have a bad cell.
I would charge on the stove top with the extractor fan running for the first dozen charges, following which your extremely unlikely to have any bother (because you won't be using toy chargers)
