Chris456345234
I am probably going to buy this battery: http://www.hallomotor.com/2015-latest-48v-20ah-samsung-icr18650-22p-cell-rear-carrier-li-ion-battery-with-flat-aluminium-case-charger-and-bms.html
But I need a rear mount rack. Not sure how this would work. If you look at the image I posted, the holes circled in blue do not go anywhere or even seem threaded. The holes circled in red, are ONLY at the left side of the bike.... Leaving me with only the bolt the holds the wheel to the frame.
And I cannot use one of those types that 'attaches' to the frame, as I got a cable on the right of the back controlling the rear chain shifter.
Seems like the only possible way this would work is if I put on some sort of adapter on the bolt in the yellow circle to reach a rear rack?
Anyone got any suggestion for adapter and rear rack that work good for big batteries like the one I listed?
