Shenta
- Joined
- Jan 19, 2009
- Messages
- 34
Hello All,
I have been reading your post, and some information have been very helpful, so I would like to point out some do and don't as a little contribution for this forum.
1. Mosfet- 4110 vs 4310 -
I have done some testing with both Mosfet, 4310 is used in some higher power controller from China (eg:1500W, 3000W...etc) for E-Bike usage, but it has greater resistance, so the heat from 4310 is higher than 4110, there for 4110 is more recommended. During high load (eg 40A ~ 50A) 4310 tend to have more problem with thermal run away, when it is "DAMAGED", it will first start loosing it's switching characteristic little by little, ( if you measure Rgs, the resistance will not drop slowly as it should be), than after a little bit while, the board will be fried alone with the transistor and diode or Mosfet driver (IRS2110 or IRS2010...etc). Another note: the price for 4310 is around USD0.75/pcs sold in China(local shop price), the fake one is around USD0.60/pcs, 4110 is cheaper than 4310... ^__^
2. Conversion form 36 or 48V to 72V+ -
There are 2 type of Mosfet driver within the controller from China, Transistor drive and IR(2110 or so) drive. For Transistor drive, the power rating is usually 40V only (to save cost), so if you hook up 72V battery, when load comes into the circuit, the whole board will be fried. Some manufacture use 80V transistor, but again, 48V lead acid when fully charged, it is measured app 55~56V, and it will be 84V+ when you hook 6 of the 12V lead acid batteries together. Problem will come when the load is high too. As for IR drive, the problem is little bit less, because by datasheet, it can sustain 100V, but however, if you use scope to see the waveform, you will be surprised how much noise you get out of it. Despite the noise, during switching, there will be a spike as high as 100V+, usually manufacture will try to use fast diode or suppressor to limit it, but again, with this kind of high voltage and speed, not many diode can be fast enough and strong enough to withstand. *the above is measured from batter to float ground or high side driver to Mosfet.
3. Modification of Soft Start -
Hub motor have tendency to draw large amount of current during start, and as for controller from China, when push throttle to max, their PWM is switching at 100%, and you can measure it from scope that with 48V, under no load, the Mosfet is switching at app. 350hz. By SOA (safty Operating Area)of 4310 or 4110, minimum switching frequency with 50V+ starts at 10Khz, so when during start, if you are completely stop, and you reduce the soft start to very little, you are sending 30A directly with no switching into Mosfet, guess what will happen?
4. Regen Break-
the regen breaking is completely total con, please be noted the max speed of BLDC motor is the max voltage we supply into it, we can not get the wheel to move faster is due to the BEMF force is as strong as the batter power we can supply, by this logic, unless in the controller there are some sort of Boost converter, than you will be only trying to charge 48V battery with less voltage supply.
I have been working on the BLDC controller for a little bit while now, things was quite confusing for me in the beginning, after blow up 500pcs+ of Mosfet and 100pcs+ of IGBT, finally started to get some down to earth knowledge. Now I am final testing 5000W BLDC controller, which use 4110 Mosfet, with Sinusoidal drive, the torque is app 35% more than conventional BLDC driver from China with same rating. And with much better thermal protection. But since it is commercial product, I could not provide any information on this, however, if there are any question when you modified your board, I am more than happy to help out.
Cheers
Shenta
4. Regen Break-
Cheers
Shenta
