Protected cells for EV are aberration, you want unprotected cells and add your own way of managing them, be it permanent with portable BMS or during charge only or during ride with an advanced ESC.
LifePo4 cells are the most stable ever done in the business, if you want chemistry which will 99% never fail you then this is it.
That's why manufacturers want to use LifePo4 instead of other types of cells when possible. Only quality LifePo4 I know are a123 systems cells, very high discharge rate, zero drift, thousand cycles before hitting the ground.
Now LifePo4 has low capacity for same weight or cell format. 18650 cells from a123 might not be available for long and are only 1200mAh. 26650 cells are the better choice for LifePo4.
But there are many quality and stable Li-Ion cells around, check the big brands. Most play with nickel, manganese, cobalt and mix it with lithium. Also some exotic ones, lithium hydrogen but never seen one in a build here, and when I ordered some unluckily I got a shipping issue not related to the seller and canceled it.
