I recently redid a low end 350W ebike that had failed, maybe still in ways I don't fully understand. It died, the battery inflated, and then the local dealer closed. It sat in storage for a long time. I recently redid the 36V battery with a new Daly BMS, and replaced the old controller with a KT36 500W sinewave and LCD8H display. Everything powers up fine and the display/controller parameters seem to configure properly.
If I start the bike under load, the bike accelerates for about 3-4 seconds then the controller kicks out. If I recycle the throttle, it does the same. If I put the bike on a stand, I can start the motor and it will keep running up to about 6 km/hr. But when I ramp to a higher speed, the hub motor starts making a racket and the controller ceases motor drive.
Here is a video ( in Spanish). https://photos.app.goo.gl/DKutCHFtuWjdTFXD7
The motor seems to be a low end 350W geared hub. I don't know how many magnets yet, I can do the cog test if necessary, does anyone know looking at the motor? Maybe geared 4 or 5 to one? How critical is the P1 setting? I also read sine wave controllers need to be paired to the motor, but I can't find a procedure and parameter to adjust. Is it the C2 phase setting? Or maybe my motor is no good at higher speeds? Any suggestions on the other settings?
