Time for more maintenance, my rear sprocket was badly worn and the chain had become really stiff.
It was hard to move some links by hand..
New chain and sprocket, but I only had a 86 tooth instead of the 90 tooth I had before.
Also new chain guides, and a little repair of rollers:
It got new bearings, the roller was fine. And I had a bunch of new bearings :wink:
I run a DID 428vx chain, but now they only had the flashy golden. I had the natural before, And I have to use 2 chains to get a long enough. I had some left from last time, and I didnt want to buy an extra golden. Those damn X-ring chains are expensive..
So I have to live with a few links in a different color
New wheel bearings (again) I cant believe how much dirt and water that got past the seals.
Maybe stainless bearings is a good option? They shouldent rust from the water at least..
And it was time to do something about the rear brake.
I have been trying to buy a new holder plate for the brake pads:
But it is not available. It is holes worn in it and pockets worn in the holder for the caliper.
When the pads is half worn or so, they get stuck in the pockets and wears on one side only.
I had to do something.
I took the only stainless sheet metal I had, It was 1,2mm thick I think.
The original plate was 0,5mm. I cut and beat on it a lot to get sharp turns, and filed a lot on the caliper holder.
After a lot of tests, grinding and filing I got it right.
(the picture is not really when it was finished)
I also noticed that the brake disc was bent, probably from a pretty hard crash when I broke off the bleeder valve on the caliper..
But I was able to straiten it. It was not nearly as hard as I expected..
Then today I rode it.
But wtf, the change in gearing made a lot of difference
I cant believe how sluggish it got from this small change.
It was most obvious from a stand still, but I could really feel the difference up to decent speed.
I changed from 8,18:1 to 7,82:1, what is it 5%?
I have ordered to get some 10 tooth front sprockets made, then I will have 8,6:1.
That will sure be interesting to try
