I'm dreaming up this go kart and planning on using bicycle disc brakes. Do they make left-side mirrored disc brake calipers?
The problem I'm encountering is that the wheel will be mounted to one side of the brake caliper. On one side the calipers will be perfect with the brake caliper arm on the opposite side of the wheel. If I mirror this arrangement, on the other side the brake caliper arm will be running into the tire. One way to deal with this is to just mount it at 180degrees rotated on the opposite side, but that introduces another set of problems. How do trikes usually deal with this?
