A while back, I was given a 48v 20ah V-Power Lifepo battery. I just checked all the cells as I was advised in a previous post, and they are either 3.3 or 3.4 volts totaling 53.6 volts after charging. Does this mean it is a healthy, usable battery? I am planning on using it with a 750w geared hub motor or 750w BBS02 I have. Will it have enough output? How does Lifepo compare to Li ion in use? I have a 48v 20ah from Luna with Panasonic PF cells and I thought about having both on our tandem trike for touring range.
