jdcburg said:
TJG – Thanks for helping me with this. Things are becoming a little more clear now. First let me tell you what happened then I’ll tell you my new plan, if everything is still working. I have a JVC controller that has a bunch of plastic connectors coming out of it. When I first got it, I hooked up the battery, motor and throttle ones and found that I had to put a bent paperclip shunt in both holes of the one labeled “ignition†in order for the controller to be activated. I also found that if I did the same with the one labeled “brake†that it cut the power to the controller/motor
I don’t read schematics and I don’t do that well with Chinglish. When I read the instructions (see one of my earlier posts) about the “short circuit,†I thought the alarm circuit would make a shunt across the red and black wires, depending on the NO/NC setting and alarm state. First I tried attaching the wires to the brake connector in the NO position. The motor ran normally. Then I switched it to NC, which should have killed the power, but it didn’t. So then I decided to try connecting the wires to the ignition plug while the celllog was still set at NC. I randomly tried to plug the black into one side of the ignition plug. I happened to pick the + side of the ignition plug and because the celllog was NC, it created a circuit to the neg side of the battery. I jumped pretty good. I tried it the other way but it doesn’t work either.
I would rather have an automatic LVC than a buzzer, so I’m going to keep trying. Let me run this by you. First I’ll check the black wire for continuity to neg in NO and NC. Should be infinity and 0, right? Then I’ll check continuity of black to neg while an alarm goes off. If that checks out, I’ll see if there is any voltage between neg and each of the connections of the brake connector. If there isn’t, I connect one side to a neg terminal and the other side to the black wire of the alarm. With it set to NO, it should shut down the controller when an alarm goes off, correct? Thanks - jd
Morning, JD. No problems helping you, as much as I am able to. I'm not an instructor, so at times I have difficulty expressing what I'm trying to say. Anyway, here we go.
First, it's a personal thing, but I don't use the word 'shunt'. I would rather use the word 'switch', because to me, that represents a means of opening and closing a leg of the circuit. In our case, we want to open or close a particular wire in the circuit. That's where the CellLog alarm port comes in. It is a switch.
It either opens the wire so that no voltage goes through it, or it connects the two sides of a wire, so that voltage does go through it. So, let's refer to the alarm port as a switch for the sake of this conversation, yes?
The paper clip you used on the 'ignition' plug was another example of a very basic switch. A manual switch, but a switch none the less. When you put the paper clip into both ports of the 'ignition' plug, you were using your 'switch' in the NC position. Right? Right!
If you remove the paper clip, the 'switch' then goes to the Open state, and the controller shuts down.
So in your situation, you want to replace your 'paper clip switch' with the CellLog's 'switch' ( the alarm port ).
In order to do that, you need to attach one of the 'ignition' plug's wires to one of the 'alarm' wires, let's say the black wire. You then attach the other 'ignition' wire to the other 'alarm' wires, the red wire.
Now, set the CellLog to have a NC alarm port. Now you have replaced the paper clip, which was completing the circuit, with the alarm port, which is doing the same thing, completing the circuit. Your controller should work normally this way.
OK, so now the CellLog is hooked up to the 'ignition' plug, and all is working as it should. You said you want the CellLog to act as a LVC, and it can do that very well. Double check the values you have the CellLog set at for LV situations. Low cell voltage, low pack voltage. Have them both set to what you want them to be at.
Now double check your bike, and make sure all works as it should. If it does, then it's time to test the CellLog to see if it will do it's job.
The way I test for that, is to go back and change one of the LV values. Use the pack voltage for this test. Change the value to a value that you know for sure is above what your pack is reading now. ( when you are changing values, it's best to do it with the CellLog powered by the usb plug, and not have it attached to the bike at all). When you have changed the Pack LV value, re-attach the CellLog to your bike, and it should go into an alarm state almost immediately. The 'alarm' switch will open, and your 'paper clip' will have been effectively removed from the 'ignition' plug because the 'alarm' switch went to an Open condition. The controller should go off, and you have your LVC circuit complete.
Give that a try, and let me know the outcome. Also, this may not need to be said, but just to cover all bases, when you are doing your testing, be sure that the balance plug is also attached to the CellLog. Seems obvious, but like I said, just covering all bases.
TJG
