El_Steak
I charge my LiPo packs with an RC Charger. My packs are deep in my rear panniers so I have to use balance connector extensions to be able to plug into the charger. Total length from pack to charger is over 3 feet with 22 AWG.
Using a celllog or battery medic, I haven't noticed any significant difference between the voltage measured right at the battery connector or at the end of the 3 feet extension.
I have seen it mentionned in a couple of places that for longer runs you have to increase the wire size to 20AWG or even 18AWG or you'll get errors in the readings.
Is there a rule of thumb for the proper length / gauge of balance wires ?
Note that those wires are strictly used for voltage monitoring and balancing. The only current going through them will be from the RC Charger shunt balancer (200ma-300ma?)
EDIT: the balancing wires for all cells have the exact same length.
