I want to make a battery that is high quality, durable and compact.
The tricky part is that it can only be about 5.3" wide and the length has to be less than 9". I'm going to be using LG M50 21700 cells arranged vertically in an egg crate pattern. The configuration is 13s4p for 48v, 20 Ah. The use will be an 1,800 watt scooter with a 33 amp brushless motor controller. It should cruise at much lower draw most of the time, the 1,800 watt brushless motor was bought for efficiency and cost, not because it needs 1,800 watts regularly.
I don't plan on doing battery fuses, I'm just going to do nickel terminal connections with spot welds. I have one of the Arduino spot welders but I need LiPo batteries for it and a charger to charge the LiPo.
I just placed orders for the cells, the spacers, insulator stickers, "4p" 0.2mm nickel strip and big heat shrink tube to cover the exterior. I have heavy gauge wire and XT90s also.
For a BMS, I have the type that Vortecks uses but I really bought it for another project so I want to wire that up in a modular way so I can swap to a less expensive BMS if I need to.
The first question is does anyone know the connector spec for BMS balance wires? I would like to buy terminals and a crimper so that I can actually have clean wiring instead of spaghetti or a bunch of solder joints.
Second question, what is the best material to use for padding and insulation for the pack? Do I need to get Kapton tape? If people can point me to examples of good DIY construction, I would love to see what is working.
Finally, what LiPo battery and charger can I get quickly and cheaply to power the spot welder?
Let me know if I'm missing any details to think about.
