Um, I can't imagine a chart that would tell you what you want for every pack in existence (whcih seems to be what you are asking for, as you give no specifics about what packs/etc you are talking about).
But basically you just add things per series-parallel rules. Stuff in series adds V, stuff in parallel adds Ah.
Amps, well, that depends on what you are doing with it, but C-rate adds in parallel just like Ah.
Your question is a little confusing. Are you trying to compare capacity of these different packs? If so you need to use watt hours which is volts times amp hours.
If that isn't what you need then go into more detail on what you are trying to compare.
