bchaney
LewTwo said:Be sure your parts list has the display unit listed.
Must of their current version display units seems to have an on/off function.
They also list a "Lighting" indicator but nothing about how it is implemented or how lights would be connected.
Good catch, I didn't look close enough at the LCD3 manual to see that. I'm trying to get the LCD5 since it's smaller and has the integrated buttons (not much real estate on my drop bars), but it looks to have the same function where it will turn on the LCD backlight as well as your head/tail lights. I found an LCD5 manual online and it gives a little more detail, it says "the controller should have headlight drive output function". See section 2.1 in the manual here - http://elektrolurchbike.de/test/KT-LCD5_kurz_engl.pdf
As far as I can tell, the only function missing on the LCD5 that's included on the LCD3 is motor temp. The LCD3 would plug directly into the controller harness included in that 11.6Ah package though. Sherry responded saying basically that, I responded this morning that I can wire it myself if they just include the wiring harness, but I'll have to wait until tonite for her response. The 16hr time difference is a killer. They have a holiday coming up so I'm trying to place the order before that.
I only have 1 HWBS on my order, I figure routing the wire to the front brake would be easiest. Is it worth getting one for the rear too?
