From my understanding of it, it makes no difference where the copper is located on the tooth with respect to the flux produced in the tooth, if it's in that slot somewhere, the flux lines are totally contained and all channeled up to the hammer of the tooth.
This motor sounds like it will have some outstanding efficiency my friend! I love how small you've manged to get your loss components.
That's absolutely the path to optimizing a system, look at your losses, understand where the come from and the relationships that effect them, then try to do everything you can to minimize the effects that cause them.
I'm personally into nit-picking how do anything possible to reduce a motors full RPM no-load power. Making a bad-ass motor is like a game where your goal is to have it capable of as much torque production as possible while still having the smallest possible full-speed no-load power. If you can do that, efficiency and high performance and everything else just falls into place on it's own.
*Edit* Wow!!! Just got to see your amazing 10,000th post my friend, and it's breath-takingly sexy copper-fill prawn! If you can achieve that wind shown (and I know if anyone can do it, you can), that motor is going to be so amazingly capable and efficient and cool running! Your copper loss component is going to be so small it's insignificant. You will have a motor that not only cruises at 1kW with possibily never-before-seen motor efficiency on an ebike, but also will have some serious current headroom if you decide to have an "off-road-only" power setting on the controller.
This would be the perfect low-inductance ultra low conduction loss power stage to match your motor. Add a few caps and drive it with a lebowski BEMF matching sensorless brain.
http://ixapps.ixys.com/DataSheet/MTI200WX75GD.pdf
