curtis.perrin
- Joined
- Jun 12, 2013
- Messages
- 26
Hi
I'm trying to setup my cycle analyst 2.3 for current limiting. I've wired it up and it does work but it is output 0V as a minimum voltage which is putting my Grinfineon motor controller into regen mode when I'm not on the throttle. Is there a way to set the minimum throttle output. My throttle goes from 0.86V to 3.7V. I've tried setting the Max Throttle and the AuxThreshold. Do I need to update the firmware? Can I update the firmware? Do I need to add a resistor or diode of some kind to pull up the min ThO? Seems really odd when the manual clearly says that most throttles are from 1-4V that the cycle analyst doesn't just mimic this by default.
