markz
100 TW
An interesting read
https://avdweb.nl/solar-bike/hub-motor/permanent-magnet-dc-hub-motor-tuning
Yeah, but but it misses the key point of the OP's question and possibly confuses the issue because people won't get past the first line on windings which is misleading due to oversimplification and unstated assumptions.markz said:An interesting read
BobBob said:For anyone who hasn't read the full thread:
Most people are happy to agree that increasing the voltage on its own will have an effect (more torque, more power, no better efficiency so more overheating)
Some seem to understand that changing the voltage/current relationship proportional to the number of windings cancels out - talking about a trade off (see mobius motor above) https://endless-sphere.com/forums/viewtopic.php?f=2&t=110990&start=25#p1652021
There seems to be controversy and confusion regarding reducing the windings having the same effect as increasing the voltage.
Just to be clear, yes, increasing the voltage has the same effect as reducing the windings whilst maintaining copper fill
Yes this does have an effect though it might be a bad effect depending on what you want.
Did you like the Mobius motor?
Torque is a function of the real world, you can change it by applying your brakes.markz said:Comparing two exact same motors with exact same windings.
Change the voltage, without changing the amps = you change the speed, torque is exactly the same. It changes total power.
Power = Voltage times Amps
Change the amps, without changing the voltage = you change the torque, speed is exactly the same. It changes total power.
Change one or the other or both, changes the power.
BobBob said:Ok so starting with two of the same motor - yupmarkz said:Comparing two exact same motors with exact same windings.
Torque is a function of the real world, air resistance and hills and applying your brakes so basically variable at will. Speed is a function of power and torque, generally, in the real world. Happy to discuss this in theoretical or real world scenarios
So, it doesn't matter how you increase the power.
To do so you must have sufficient volts to drive the current so, if you haven't then it simple doesn't happen,
Assuming you do, then:
Increase the volts by 10% or increase the amps by 10% then you increase the power by 10%.
if you are able to do this then it doesn't matter how, you are dissapating that power somehow
You now have 10% more power, you can go faster or have more torque, you might go up a hill or down a hill and the power output will exacty and perfectly match your input, there will be losses due to copper and iron.
Speed will be force X distance. if you go faster there will be less torque, if you go slower there will be more.
Losses will be greater for copper at low speeds and iron at high speeds but largely irrelevant for this discussion.
If you increase the power then fix the speed you must have increased the torque
If you didn't increase the torque you will go faster, where else could the power go?
But you said:markz said:Where will the power go? It could go into heat loss. Say going up a % slope will reduce speed and increase heat loss.
With the same battery, opening the throttle changes the PWM which just changes the (average) current,markz said:Change the amps, without changing the voltage = you change the torque, speed is exactly the same. It changes total power.
No probs, it's funmarkz said:But I am going off on a tangent with you on purpose there.
You're gonna need more torque and therefore less speed to get up that hill with that same 1000Wmarkz said:1000W = 50V x 40A, lets say thats 30mph which can get you up a hill at say 20mph. But now you go 1000W = 60V x 15A which is 31mph but can only get you up a hill at 8mph. 15A less torque to get up a hill.
Generally around 15-25 Mph but for steeper hills go faster to reduce copper lossesmarkz said:Lets throw a curve ball in there just for ya. Whats the optimal speed to go up a hill in terms of Wh used and heat. Do you go up that hill fast or slow?
I guess you could go slower or pedal harder if you have less money?markz said:Speed will be reduced due to air resistance the faster you go, which requires more power to get over that air resistance. More power means more battery, means bigger battery, means costs more, means a new controller or modify your current controller with larger capacitors and better mosfets and beef up the shunts.
