teslanv
This is a mod I did for a recent build. It's a simple inline switch added to my front ebrake circuit, that allows me to disable the front ebrake and still engage the motor for "warming up a tire". This is often referred to as a "Line Lock".
I used a standard 3-position switch, that has a three-wire output, though you could also use a two-position switch with two wire output for the same effect.
Essentially, you just interrupt one of the ebrake wires with the switch. When the switch is "On" (closed), the ebrake circuit functions normally. When you switch it "Off" (Open), it disables the ebrake circuit (tricking your controller into thinking the ebrake lever is not being activated.)
And then you can light up your tire.
[youtube]2V399UC3GU0[/youtube]
