One important advantage over other lithium-ion chemistries is thermal and chemical stability, which improves battery safety.
[6] LiFePO4 is an intrinsically safer cathode material than LiCoO2 and manganese spinel. The Fe-P-O bond is stronger than the Co-O bond, so that when abused, (short-circuited, overheated, etc.) the oxygen atoms are much harder to remove...
... As a result, lithium iron phosphate cells are much harder to ignite in the event of mishandling especially during charge, although any battery, once fully charged, can only dissipate overcharge energy as heat. Therefore failure of the battery through misuse is still possible. It is commonly accepted that LiFePO4 battery does not decompose at high temperatures.[6] The difference between LFP and the LiPo battery cells commonly used in the aeromodeling hobby is particularly notable.
