IvanGrozny
10 µW
- Joined
- Jul 6, 2018
- Messages
- 5
So, I am getting ready for my 3rd season with my ebike. There are some changes and upgrades I want to do but before I want to be sure I understand what I am doing.
My bike is a Cannondale F700 with a Voilamart brushless hub motor36 V, 500/750 watt controller. PAS not installed. I have been using a self made 10s2p battery pack made from SPIM08HP lithium polymer cells 3.7v/8ah each. The cells are capable of 200 amp continuous discharge and 400 A burst for 3 seconds.
I would like to upgrade my controller and increase the voltage, probably to 51.8/58.8, 14s1p. My main reason for this is not to effect any real increase in speed. I am happy with the 20-25 mph I get on the flats for my commute. I would however like better performance on the couple of small hills/slopes I have on my short 1.5 mile commute. I am a big guy, 280 lbs, and yeah I now know i should have gone with a higher voltage/wattage kit. Range is not an issue, when I first built the bike I ran a 10s1p pack for several weeks and got about 3 days commute out of it between charges
Questions;
1. As I understand the voltage and wattage are controller dependant more than specific to the hub motor?
2. Hub motors can run over a wide range of voltages/wattages from what I've gathered?
3. When choosing a controller can I up to a 1500 watt 48V or should i stick with a 48V 1000 watt without damage to the motor. (the voilamart 1500 watt motor weighs like 10 lbs more than the 36v 500/750 or 48 v 750/1000 motor does)
Budget is a serious consideration so I wont be buying an expensive controller, but I am thinking of buying a bluetooth BMS so I can monitor the battery/cells. I am also planning a few superficial upgrades like sensors on brake levers rather than the crappy brake pulls that came with the kit, replacing the lousy freewheel that cames with the kit, switching out disc brake caliper with one that can be adjusted in place (bb7 I think it is, has a wheel that is reachable in spite of the motor).
Questions;
