boisrondevens
I have put a neugart ple80 in line with a scorpion.
The controller is a crystalyte 72v 60amps
The motor is a scorpion s5535
Specifications
Stator Diameter 55mm (2.165 in)
Stator Thickness 35mm (1.378 in)
No. of Stator Arms 18
Magnet Poles 20
Motor Wind 10 Turn Delta
Motor Wire 29-Strand 0.25mm
Motor Kv 190 RPM / Volt
No-Load Current (Io/10V) 1.56 Amps
Motor Resistance (Rm) 0.024 Ohms
Max Continuous Current 90 Amps
Max Continuous Power 3800 Watts
Weight 855.6 Grams (30.18 oz)
Outside Diameter 65.4 mm (2.575 in)
Shaft Diameter 7.98 mm (0.314 in)
Body Length 79.5 mm (3.120 in)
Overall Shaft Length 126 mm (4.96 in)
Max Lipo Cell 12s
Motor Timing 5deg
Drive Frequency 8kHz
Weight including packaging
1800g
Data Chart
View Scorpion S-5535-160KV Data Chart
I change the wires to wye to get 94 kv
The motor get verry hot in no time. I also use a optical sensor as u can se in the video.
Any idea y the heat?
Specifications
Magnet Poles 20
Max Lipo Cell 12s
Motor Timing 5deg
1800g
Data Chart
