boisrondevens
Hi
My project is to built a drive system so the neugart ple80 will be inline with the motor.
This motor as 20poles. Do u guy think a can rewind this motor to obtain a lower kv?
Maybe to get 100 to 130kv
Specifications
Stator Diameter 55mm (2.165 in)
Stator Thickness 35mm (1.378 in)
No. of Stator Arms 18
Magnet Poles 20
Motor Wind 12 Turn Delta
Motor Wire 26-Strand 0.25mm
Motor Kv 160KV RPM / Volt
No-Load Current (Io/10V) 1.18 Amps
Motor Resistance (Rm) 0.032 Ohms
Max Continuous Current 85 Amps
Max Continuous Power 3600 Watts
Weight 858.9 Grams (30.30 oz)
Outside Diameter 65.4 mm (2.575 in)
Shaft Diameter 7.98 mm (0.314 in)
Body Length 79.5 mm (3.120 in)
Overall Shaft Length 126 mm (4.96 in)
Max Lipo Cell 12s
Motor Timing 5deg
http://www.scorpionsystem.com/catalog/discontinued/motor/s55_2/S-5535-160KV/
Thanks for the replys
Specifications
Magnet Poles 20
Max Lipo Cell 12s
Motor Timing 5deg
