Jestronix said:
How much heat energy is lost when using a square wave controller vs sinewave . I know on inverters square wave cause motors to run hotter, but is this true on controllers?
The added heating would be precisely the efficiency difference between the two operating strategies.
So, if you're running say 1kW, and trap drive is say ~85% efficient, and you switch to sine drive and it's ~90% efficient, then trap is heating the motor with ~150W of heat the shed, and sine is heating it with ~100W of heat to shed.
Those values of improvement are actually realistic for many motors, but if the motor happened to be created to have trap-wave shaped BEMF, then switching from trap drive to sine drive could even hurt efficiency rather than help it. That said, a motor designed to have trap BEMF is going to suck at everything anyways.
