Hi guys
I have a stealth bomber I have stripped down the motor to replace the bearings and have noticed the wiring is looking more than a little sorry for itself
Can I sleeve over each wire with heat shrink or do I have to Re solder and if I do do I have to Re solder do I have to go to the motor connector or could I cut the wires and solder to each wire and then heat sleeve over the top
I assume this is due to the heat of the motor
