Does anybody know what that stands for error code wise? My app isn't working right now so I'm not getting any info I mean the app works. I just don't have the connection properly settled for the Bluetooth Bluetooth. it's a 721800.
Here’s this gauge that increases and decreases the LED light from 0 to 100% as a twist the throttle as smooth gradient increase. I don’t know what the left battery indicator light means I replaced the 9 V battery inside maybe I need to hook it up to the actual battery of the bike
Where you able to do an Auto-learn.
During this the controller learns the throttle settings. If your throttle has lower or higher settings the controller will show a throttle error and will not spin the motor.
Yeah, that thing has been bugging me but not at all Not wanting to do it because it’s easy to throw it in test mode or learn mode but the problem is I can’t get to the app hooked to the bike yet. I’m going to the wiring right now but it’s causing me that’s the third problem. I got the hall sensors wires taken care of now it’s throttle, but the throttle is related to the app connectivity
You know what turned me off about working on the throttle learning was that I put two different throttles on and they both had the same error of Long Beach‘s, and that’s a weak ass concern because to throttles both could have the same set up that needs adjustment so I’ll just get that app hooked up
