No , if it was possible before regen then it should also be possible after regen.
Is it a common port bms? If not regen will not work.
Could you post your settings? Maybe I can compare with mine and see what might be the issue.
Another thing you could try is reset to factory settings and just change the few most necessary settings to get it to run.
Then see if the issue still persists.
-My battery: 60V 30Ah (factory original battery -1-year-old and no access to BSM)
-Controller: far driver 72V240A
-Max line current:40A
-MAX phase current: 240A
rated Volt 72
overvoltprotect 90 and restor 88.7
Lowvoltprot: 50v restore 52v
Lowvolway: 0-Vol2V ( other throttle functions under protect are all set to 0)
30KW max power motor (but I think given my battery the rated power is set to 1500W. So practically max RPM is somewhere around 4000-4500)
Gear one is set to 70% line and phase current and has an RPM limit of 2500 while gear 2 is set to 100% line and phase with RPM above max RPM ( 7500; so no limit )
The problem is if I turn on regen in function >follow >3EABS when-release with any Stop back current and -maxbackcurr I get a problem with cut of power after a regeneration session until I fully stop the motor. On the other hand, I don't see any problem if I do the regeneration through braking, even at 10 A
So it gives me the assumption that maybe EABS-when-release is not compatible with my system or short braking does not generate enough current to cause a cut of power as a result (I use throttle far more than brake for adjusting the speed). In base parameters (first page before entering the pro section ) I also see settings energy feedback . However, this setting uses other terminology. For example, there is something like brake generate slightly or throttle generate slightly or strongly. and it does not change by clicking on it.
In the regen section,I also have problems with changing the free throttle or any of the RPM variables . Entering a number has no effect and nothing will change. It remains zero. Again, I don't know if there is a problem with the controller or my setup does not allow such a thing. I also for example could not set my wheel data under the display section. Speedometer is slightly off from GPS speed (over speed). <don't know if I should change the speed plus for it? I don't know maybe I really should reset it? By the way, is there any way to lock some settings on this controller on PC version? I bought it from China and they adjusted some parameters based on my specification. I am wondering if they could lock some setting
