Deutch420
So ive been running a GM hub on a Lyen 12FET over the summer @ 100v 40amps. Everything worked flawlessly. It was fun, but i wanted more power.
So i recently got my hands on a 5304. I also got a 18FET from lyen.
I got everything together and went to tune it. here is a screen shot of the tune. 100v
![500.jpg 500.jpg](https://endless-sphere.com/sphere/data/attachments/39/39527-745aa436d5747a1b41f7a923d400713d.jpg)
Bike rolled great, very quiet. However, there was no power! From 5mph if i went WOT i would only see a 5 amp draw on the CA and the bike was terribly slow. So back to the drawing board i go.
With some help from a forum member and lyen i was advised to change the Rshunt in the CA to 1mohm. So i did. I also made sure the max amps was set to 90 and the max speed was set to 90 to avoid any restriction from the CA.
So i go back out. Wile there was an improvement, the bike was still very slow. If i went WOT at 5mph i was seeing 1000watts (even with my block time set to 3+) and once i hit 20+mph it would go to 2000watts until i hit 35mph - which appears to be my max speed. It takes about 15 second for me to go from 5-35mph. I presume with 100v 50amps and block time to 2 i should see 70+ amps under load down low with a top speed of 50ish mph. On my GM hub with the 12FET @ 40amps 100v i would do 0-45mph in 12 or so seconds so. with block time set to 1 and 40amps i would see 50-60amp draws under WOT at times. if i had to take i a guess, i would say this setup feels like my GM would feel at 72v 10amps. meanwhile its a 5304 at 100v 50amps!
All the phase wires are elongated with 10g high temp silicone. None of the connections or wires get hot or even warm. been soldering for years. all wires were resistance tested and were good to go. So no wiring issues. Phase and hall are hooked up correct. bike runs smooth. (but for those that are curious; phase is green to green and swap other 2. Hall is yellow to yellow swap other 2. red to red black to black.)
Anyone have any ideas? I did get the hub used, but it looks brand new for the most part. Spins fine. Phase and hall wires are not, and look like they never were, melted. Battery is hooked up correct. This is veriefied with my 8m battery monitor, CA and icharger. This pack was used multiple times and nothign was changed. There is no abnormal voltage sag under load. If i didnt know any better i would say the bike is stuck at 10%, but the math (Volts x Amps = W) doesnt work.
So long story short, i have a 18FET controller, tuned to 50 amps running at 100v. for some reason my max speed is 35mph and it takes me a long time to get there. I see 10amps under 10mph (regardless of the slope of the road, or terrain. uphill's cannot be climbed and grass brings me to a crawl) and a max of 30amps on a flat paved road.
Im hoping i just missing something silly. Maybe someone here caught it?
Thanks and sorry for the rambling.
Any information needed to help, please ask!
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Rolling Eyes :roll: :roll:](/sphere/data/assets/smilies/icon_rolleyes.gif)
